Fast acquisition with DAQ
Dear members, this is my 1st Labview code.
What I have : Labview 2018 + USB-6361 BNC card
What I need : (to monitor an electrolytic process that last for about 1 hour)
a- record multiple analog input channels
     - for a time window of about ~0.5ms
     - every ~5 minutes
     - for about 45 minutes
b- (desired/not needed) show the results "live" during the whole 45minutes and the last recorded "event"
So the code I have gets this done... but :
- the waveform chart is not readable... the time elapsed between acquisitions is too big so my events only show as a line... still, solving this is desired but not mandatory.
- if I put the STOP DAQ TASK outside the while loop, the trigger only works once, so my acquisitions start in a random moment. If I put the END TASK inside the while loop I get a very heavy code taking a lot of time to complete one iteration (with virtual signals works fine, but not with the real card and a signal generator).
- I apologize, the code is in french
- I need to record at ~100kHz / 0.5ms --> about 50 samples
So, the lower half of the code seems to work I even disabled it for testing, but it changes nothing.
Message 1 of 18
(2,226 Views)
We can't really analyze "pictures" of code, so please attach your VI.
What I can tell immediately is that you have glaring race conditions due to blatant overuse of local variables. You cannot tell in which order the terminal is written or the locals are read, but the result depends on correct order. LabVIEW does not execute left to right and execution order is purely determined by dataflow. There is no way to determine execution order of all your disconnected code islands.
Message 2 of 18
(2,205 Views)
Have you looked at the "Continuous Measurement and Logging (DAQmx)" project template that ships with LabVIEW and DAQmx? You can access that excellent code from the menu>>File>>New...>>Project from Template.
"Should be" isn't "Is" -Jay
Message 3 of 18
(2,175 Views)
Hi, I don't seem to have project templates
And from help>>search for examples >> I got a few hints that led me to my actual code, but none of the ones I saw actually used a continuos acquisition with analog trigger
Message 4 of 18
(2,153 Views)
I got rid of most of the local variables... There is still one to modify a control... a shift register would not be useful for this, would it?
I thought I was making the vi "more readable" by using local variables (I guess that should be a common excuse to justify bad coding practices among us, newbies)
The "new" vi is attached
Message 5 of 18
(2,146 Views)
Those are VI Templates! You want the Project Templates.  Possible easier to get to from the Getting Started Window.  There is a menu option to show the GSW too!  ???View>>GSW??? I think.
Message 6 of 18
(2,124 Views)
So "I got it"...
but I cannot run it
but from what I could see, this code (that is clearly beyond my current skills) doesn't seem to be triggering
Message 7 of 18
(2,067 Views)
anyone with an idea?
Message 8 of 18
(2,015 Views)
Hi George,
Activate the missing "professional" license as indicated by that error message…
Message 9 of 18
(2,013 Views)
I doubt that my company will accept to buy a different licence from the one we already paid, in order to get running an example that might not help at all with the problem that I have.
But thank you for your answer.
Message 10 of 18
(2,008 Views)
