Fast AI AO with cRIO
I have recently been using a modifed version of the example "Multi-Function-Synch AI-AO.vi" for my PCI-6259 to simultaniously generate and measure sine waves and varying from 1 to 20kHz using the AI and AO channels in finite sample mode. It would be great if a similar strategy could be implemented in my cRIO, but is this possible?
Best regards
soeren
(2,534 Views)
Hi Soeren,
This can be done, although it will be slightly different I believe due to the presence of the FPGA on the cRIO. I believe this thread will be of assistance to you - it contains some instruction and example VI's to assist you.
I hope this helps, and I wish you success in your application.
Mike W
National Instruments UK&Ireland
(2,511 Views)
