Failure"datatype.cpp"line 2672 Labview crashes while mesurement
Labview crashes while running a measurement without saving any data.
Failure"datatype.cpp", line 2672
LabVIEW Version 6.1
(3,316 Views)
Can you send the log file associated with this error.  You can find out where this is in this KnowledgeBase.
What kind of measurement is causing this problem?
(3,298 Views)
Hello Brian
The error log file is drwtsn32.
The error pops up when I try to do PCT measurements on the PCT Pro.
(3,288 Views)
I would suggest disabling the Dr. Watson utility on your computer.  The drwtsn32 error file is not a LabVIEW error - you can refer to the following KnowledgeBase on finding the Dr. Watson log file.
(3,268 Views)
Brian,
The error problem is still not solved. I think it is a LabView error.
Disabling the Dr Watson utility didn't solve the problem.
Please let me know if you need any other information about the error.
Lois
(3,235 Views)
Which VIs are you using to take readings from the PCT?
One suggestion that I saw work for another customer was to try to mass compile.  Another suggestion I saw people with this error do is try to convert any typedefs to strict typedefs.
(3,217 Views)
