Failed to create files with write to measure.vi
Ok,
You are getting the Error 74 because the TCP functionality isn't working properly at the moment, basically the TCP is timing out which is causing the Error 74.
I'll try and work out why the TCP is connection is failing, that should hopefully solve the problem.
Dom
PS network comms with cRIO's is in my experience a real b**** to get right first time!
Message 61 of 77
(1,165 Views)
I am getting some very wierd behaviour from my cRIO at the moment.
So I am really struggling to test the vi I sent you, sorry!
Message 62 of 77
(1,162 Views)
Hi Dom, that's ok! Thanks a lot for the help!
Message 63 of 77
(1,156 Views)
Hi, If I want to provide only three options (three buttons) of sampling frequency to the users,is radio button a good choice to use?
Message 64 of 77
(1,153 Views)
Hi Gregor, I have just implemented a radio button control onto the computer.vi to allow for options of different sampling rate. So far its been running smoothly but can you please have a quick check to see if there are rooms for improvement? However, the problem still exists in which the cRIO.vi shuts down by itself at the start. Thanks!
Message 65 of 77
(1,144 Views)
The cRIO shutting down may be the result of your "Stop" button being of the wrong type,
Right click on your stop buttons, and select one of the "Latch when..." options.
Dom
Message 66 of 77
(1,132 Views)
Hi Again,
I keep forgetting you are controlling it from the PC, it may be that the "Stop" variable has a hangover in the network, or stored on the cRIO.
Try putting a case structure around the stop variable, wiring the "i" value into the "?" on the case structure, then changing the case structure so that on the 1st iteration you feed a constant, "F", into the stop control, but for all other values of "i" you feed in the network variable "Stop".
Do this on both loops, hopefully this will solve the issue.
Let me know.
Message 67 of 77
(1,129 Views)
Sorry Dom, I dont really understand your instructions. How can i write an "i" value into the "?" on the case structure? And which stop variable do u want me to put the case structure around? There are three occasions where I have used a stop variable, two in cRIO.vi and one in the computer.vi
Is it possible for you to show me a screenshot? thanks!
Message 68 of 77
(1,117 Views)
Try this VI.
You can wire pretty much anything into the "?", AKA the selector terminal, you just have to define what to do for each possible case.
Dom
Message 69 of 77
(1,111 Views)
Thanks! But I cant open it coz i am using 2009 lol. Can u please down convert it again?
Message 70 of 77
(1,109 Views)
