Facing a problem in creating a report in to Excel File.
Hi
I want to create a excel sheet which contains 3 coloums whose inputs are 2 integers and 1 float.
I tried to convert these inputs in to 2D Array through build array. But the build array is not giving
the 2D array as output which i want to transpose.
Thanks in Advance
Rohit
(2,710 Views)
Hi Rohit:
As arrays group data of the same type, you can't have an array of two INT and one DBL.
You may need a second Build into array to get the 2D array you want, but it will be DBL 2D Array.
Aitortxo.
(2,706 Views)
Thanks Aitortxo.
Plz tell me one thing how to append in to a file because it is always overwriting the previous value.....
Regards
Rohit
(2,689 Views)
Hi Rohit:
If you are using Report Generation Toolkit, every function that inserts data has a START input (Excel Easy Table, for example), where you specify the leftmost top cell of your insertion point.
You should set this value conveniently
Hope it helps,
Aitortxo.
(2,680 Views)
