Face 32 warning after open .vi of LabVIEW7.1 by LabVIEW2019, How to solve?
I face 32 warning that make the RUN Button is broken, how to solve below warning?
C:\Flex Attach\Vela_AX Flex Attach_15s_XP 09Sep18\Flex Attach System.vi (Flex Attach System.vi)
- LabVIEW changed a constant that was wired to a Case structure to a hidden control to maintain compatibility with LabVIEW 7.1 and earlier.
C:\Flex Attach\Vela_AX Flex Attach_15s_XP 09Sep18\PopUpAlphaKB.llb\HMI Pop Up Alpha KB.vi (HMI Pop Up Alpha KB.vi)
- You will no longer receive mouse up events after a drag and drop operation. You will receive the Drag Ended event for the drag source control instead.
C:\Flex Attach\Vela_AX Flex Attach_15s_XP 09Sep18\PopUpAlphaKB.llb\HMI Pop Up Alpha KB02.vi (HMI Pop Up Alpha KB02.vi)
C:\Flex Attach\Vela_AX Flex Attach_15s_XP 09Sep18\PopUpAlphaKB.llb\HMI Pop Up Alpha.vi (HMI Pop Up Alpha.vi)
C:\Flex Attach\Vela_AX Flex Attach_15s_XP 09Sep18\Master X_Y Verification.vi (Master X_Y Verification.vi)
C:\Flex Attach\Vela_AX Flex Attach_15s_XP 09Sep18\Model Select.vi (Model Select.vi)
C:\Flex Attach\Vela_AX Flex Attach_15s_XP 09Sep18\Production.vi (Production.vi)
C:\Flex Attach\Vela_AX Flex Attach_15s_XP 09Sep18\Run.vi (Run.vi)
- The File Dialog function now outputs an error cluster. An Unbundle function was inserted to maintain compatibility.
C:\Flex Attach\Vela_AX Flex Attach_15s_XP 09Sep18\System Initalize.vi (System Initalize.vi)
C:\Flex Attach\Vela_AX Flex Attach_15s_XP 09Sep18\X_Y Evaluation.vi (X_Y Evaluation.vi)
C:\Flex Attach\Vela_AX Flex Attach_15s_XP 09Sep18\X_Y Verification.vi (X_Y Verification.vi)
Best Regards,
NirutG
(1,427 Views)
They are just warnings. They don't make your code broken.
Click on the Run button to see what's really wrong.
Paolo
(1,421 Views)
Thank you very much.
(1,342 Views)
