FTP help
hi ,,, friends.....
i need to tranfer one JPEG file from one pc to another....
lot of time i have played with only udp to tranfer data packets.... but i need to tranfer jpeg file....
so now i have to use FTP service... am NOVICE to this protocol....,
can anybody help me for this.......?
(2,485 Views)
As you are quite familiar with UDP you may consider using TCP to transfer your file(s). LabVIEW comes with example VIs that cover the usage of the TCP functions.
Actually, FTP bases on TCP. If you want to save some time you might consider using the NI LabVIEW Internet Toolkit which comes with a FTP palette.
(2,475 Views)
