FTP from cRIO to host PC not working
I have a VI that writes files to my cRIO 9074. I then need to get those files onto my PC. I want to do this running on cRIO (as opposed to from my computer) so that I can have a 'export file' button in the VI. I'm therefore using the 'Put File' FTP function, and have set up FileZilla as the FTP server on my PC, as delineated here: http://digital.ni.com/public.nsf/allkb/9A004CF5241F3CB68625779E004EE159
However, the file does not copy and I get an error message.
Details and annotated screen captures below.
Thank you for your help!
Elizabeth
  • I can do the reverse (running VI on computer, get or put files from/to the cRIO). However, I'd like to run this from the cRIO
  • If there's a way to call a VI on the computer from a VI running on the cRIO, that's also an acceptable solution
  • I can tell the cRIO is connected because I can access it via FTP from my computer
  • I've set up the FTP server with the default server (127.0.0.1), and user LABVIEW with the appropriate home directory etc., with read/write permissions
  • In the Put FIle VI, I have the host set as my computer's IP address, and the user again as LABVIEW
  • The error code I get is Error 1: TCP Write in NI_InternetTK_FTP_VIs.lvlib:FTP Command.vi:6->NI_InternetTK_FTP_VIs.lvlib:FTP [QUIT].vi->NI_InternetTK_FTP_VIs.lvlib:FTP Close Session.vi:3->NI_InternetTK_FTP_VIs.lvlib:FTP Put Multiple Files and Buffers.vi:2->NI_InternetTK_FTP_VIs.lvlib:FTP Put File.vi:1->RIO_FileExport.vi
(3,917 Views)
Just a guess but try changing the active/passive setting. Have you tried FTPing to the PC from another PC? Does that work?
(3,907 Views)
Thanks for your reply. I've tried with both active and passive settings, and get the same result. I don't have another PC to ftp to this one to, unfortunately. Any other suggestions?
Thanks!
Elizabeth
(3,878 Views)
