FTP Get File.vi is returning an error
I'm MANUALLY able to get a file from an ftp server. From the same machine, when using LabVIEW's internet kit, FTP Get File. VI it returns an error (error code 66): "TCP Read in TCP Read xTP Reply.vi:4->FTP Get Command Reply.vi:3->FTP Data Receive.vi->FTP [RETR].vi->FTP Retrieve Multiple.vi->FTP Get Multiple Files and Buffers.vi->FTP Get File.vi"
I have set the VI properties as follow:
BINARY  True
Active    False
Furthermore, I see an error in the "file error":  Open File, error code 1059
Can someone please help?
(4,554 Views)
Where you able to run the FTP Browser.vi from the examples?
Here is a thread discussing the same error using ftp, it might help:
http://forums.ni.com/ni/board/message?board.id=170&message.id=389149&requireLogin=False
Christian
(4,532 Views)
Maybe the problem is not with FTP, but rather the name or location of the target file. The filename may not be acceptable on your platform, or the location might be a folder with permissions or quota limitations...
A search for Error 1059 on this forum returned this message which may be of help...
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=415350#M415350
Message Edited by Phillip Brooks on 11-12-2009 07:22 AM
(4,524 Views)
