FSK modulation
    how can i edit the example of FSK modulation i downloaded from NI.com to show modulation waveform graph instead of only IQ data and Spectral analysis graph??
(4,653 Views)
Hi Serina,
see the attached example please. I hope this helps.
Mike
(4,639 Views)
Hi Mike,
           I cannot run the program you send me and the VIs added by you is another language, which is different from mine (is not english). I think because is different version so i could not run it.. Smiley Happy
(4,632 Views)
Hi Serina,
which LV version do you use? The different language should be no problem.
Mike
(4,629 Views)
I can run the program already but i still don't understand the graph and get the desired waveform i want. It is just a high curve that is barely visible by the top of the graph.
can you help me or explain to me? Thanks!
(4,622 Views)
Hai serina,
Try reducing the amplitude level in ur graph.
Hope this helps.
Mathan
(4,617 Views)
actually is already very low is between 0.99 -1 so i am very bewildered too..Smiley Indifferent
(4,610 Views)
