FRF real imaginary
Hi
I want to make a dual channel spectrum analyser using the FRF real-imaginary.vi. Does any body know any examples of using this vi.
Mal
(2,739 Views)
If you use real-imaginary, are you planning to plot on a Smith Chart?
The magnitude-phase version is used in the example called Frequency Analysis of a Filter Design. The real-imaginary version is used in the example called Nyquist Plot of a Filter Design.vi. These can both be found through the example finder.
Hope that this helps,
Bob
(2,733 Views)
