FPGA
I am using a PXIe 7962 Flex RIO module with a 5781 adapter module. I have multiple bit files that I want to load pragmatically. All the bit files have the same clocks and FIFO's. Is there a way to load the bit files dynamically at run time based on the user action?
Thank You,
Sharath
(3,134 Views)
Yes, you can have multiple instances of "Open FPGA VI Reference", each one linked to a bitfile. Place them in a case structure and load the desired one. Make sure to have "Dynamic mode" checked in the Open FPGA VI Reference properties, else the references don't match.
(3,112 Views)
As has already been said, you can open/change your bit files as much as you want.  Just remember that you can only have 1 bit file (FPGA personality) loaded at a time.
(3,104 Views)
