FPGA synchronisation of I/O-Node and variable values / 1 ms delay problem
Hi Intaris,
I think you are absolutely right. I totally forgot to consider the delay of the Delta-Sigma module. Embarrasing.
@MS_Sitec
If you want to have the signals synchronously you have to delay the signals with a smaller delay so the input delay is compensated.
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
Message 11 of 15
(1,398 Views)
There's no embarrassment neccessary.  Given the amount of things we need to take into consideration when pondering such questions, it's no wonder that the occasional fact slips through the cracks.
Comparing signals with different origins (On-FPGA and Off-FPGA) is always a bit more complicated.
Message 12 of 15
(1,395 Views)
Very kind Smiley Happy
Nevertheless something that really should be obvious. The expression which came to my mind, when I read your remark (which should be the English equivalent from the German one): the scales fell from my eyes
Thank you for your help!
Message 13 of 15
(1,390 Views)
Wir können uns auch direkt auf Deutsch unterhalten wenn's besser passt. Smiley Tongue
Message 14 of 15
(1,387 Views)
Many thanks to all!
My quick check program test failed because of the dependencies with the SPS.
But I´m sure the input delay as mentioned by Intaris is the reason (= 0.78 ms @ 50 kHz). Through it is a constant value I try to compensate it in software.
MS
Message 15 of 15
(1,357 Views)
