FPGA oscilloscope to measure power and voltage
I need to create an onscreen oscilloscope, to measure the power and voltage from a detector, using FPGA and LabView. I am attaching the VI. Can someone tell me what I should add to make it an oscilloscope?
(2,711 Views)
What hardware are you using?  I think you should check out the examples.
The code attached will not work as the data out needs to go from the I/O to a DMA-FIFO and then to a GUI VI (two VIs, one on the FPGA and one on the Host).
ALE Consultants
(2,686 Views)
hi,
I am using Ni USB 7856r Xilinx FPGA.
I am attaching the host and target vi I made but I am not able to read anything.
(2,674 Views)
