FPGA dynamic reference broken (FPGA Interface 2010)
I am trying to use the new "FPGA Interface 2010" feature of dynamic FPGA references to use the same code for different targets. However, I am getting a broken FPGA reference wire that doesn't make sense to me:
The "clock 1 settings" the error hint is referring to is a simple strict-type-def cluster on the FPGA VI front panel. I was previously having the same problem with a strict-type-def array. When I replaced that array by a cluster (NOT the "clock 1 settings cluster, though!), the problem just jumped to another front panel element (i.e., the "clock 1 settings").
What does "Register is different" mean?
When I open the FPGA VI reference I use exactly the same bit file as when I configure the FPGA reference in the class' private data (to which I try to write to above when getting the broken wire):
Am I doing something wrong or did I hit a bug the new FPGA module?
(4,030 Views)
Could it have to do with the strict type defs?
(4,019 Views)
Hi dlanger,
it is very likely due to the typedefs as dynamic references don't completely support them yet.
Does it work without them? If not, then there might be another reason.
(4,005 Views)
Would there be in the near future support for it through a patch?
(3,973 Views)
I believe this will be possible in a future version, but probably not as a patch to the current version.
regards,
(3,971 Views)
