FPGA data mismatch
Hi
I am trying to send a data packet of 9 bytes to a stepper motor driver over FPGA on a cRIO 9066. The first VI I used was built entirely on the FPGA and I successfully sent the data. When I moved the data array to the host/computer and kept just the I/O on the FPGA, it insists there is a data mismatch. Why is this? I would really like to be able to send the data from the host as it changes based on what I am trying to get the motor to do or read from the onboard encoder.
(2,655 Views)
Hi sidpen,
which kind of "data mismatch" is worrying you?
On the RT side array size is handled dynamically, while the FPGA insists on fixed-sized arrays. Probably you get a coercion dot because of this "conversion" to fixed-sized…
(2,652 Views)
