FPGA compiling inconsistency
Dear all,
I have a simple FPGA PID program.  The program compiles and runs nicely when in the original Project underwhich I wrote it.
I was trying to add the program to another project, contained in separate folder, but could no longer compile the FPGA vi correctly;
Compilation seems to start normally, but after 6 minutes of compiling, the Complation Status window shows the following Summary report:
'Status: Compilation failed.
Refer to the Xilinx Log report for more information, or contact National Instruments technical support at ni.com/support.
Device Utilization
Total Slices: 15.7% (4512 out of 28800)
Flip Flops: 9.8% (2832 out of 28800)
Total LUTs: 10.9% (3125 out of 28800)
Timing
None.
Actual Xilinx Options
Synthesis Optimization Goal: Speed
Synthesis Optimization Effort: Normal
Map Overall Effort Level: Default
Place and Route Overall Effort Level: Default
Start Time: 10/27/2011 1:39:10 PM
End Time: 10/27/2011 1:45:41 PM
The compilation failed'.
To check whether I made a mistake
while copying things over, I reopened the original program under the original Project and compiled it successfully.
I have no idea at all why the copied program, exactly the same as the original, does not compile.  I have tried restaring
labview, the computer and moved files around.  None of these solved the problem.  Any suggestions?
Thanks in advance.
(2,444 Views)
Hi
So where did you add the FPGA VI in the other project ? Are there more than one FPGA VI present in the new object?
Did you have a look to the compiler report ?
Screenshots or project would be very helpfull.
Kind regards
(2,415 Views)
