FPGA compiler
Hi everyone,
I'm trying to build a project using the sbRIO-9651 SOM for the first time.
I have windows 10 on my computer , labview 2018 and labview FPGA local compiler vivado 2017.2.
I opened the sbRIO-9651 CRB Getting Started example connected to the sbRIO and tried to compile the FPGA vi but every time I'm trying to compile I get the error: compilation was aborted by the server.
I tried to disable temporarily the anti virus and the firewall - it doesn't help.
I tried to reinstall the FPGA module and the FPGA compiler - it doesn't help too.
I attached to this post image and video of the problem..
I'll be very grateful if anyone can help me figure it out.
Thank you,
Noy.
(2,569 Views)
Hello!
Are you connecting the PC to the sbRIO through an ethernet wire or a USB?
Could you check in NI MAX if there is any error or warning on your sbRIO connection when you see it under devices and interfaces?
(2,516 Views)
I'm connecting the sbRIO through the USB connection.
When I look at the NI MAX I see the sbRIO under devices and interfaces but there is no error or a problem.
Noy.
(2,509 Views)
