FPGA compile
Hello everyone,
I use IC-3173 to do a project recently. This project aims to achieve the image transferring from host to target by DMA FIFO. But when I compile the UI Main.vi, it has a problem, I attach it below. My project refers to the example from Vision FPGA named "Flat Field Correction on FPGA", I run the example and get a same problem, the LabView said there was a IP integration node error, I don't know how to solve these problem. All the versions of my software are 2020.
Message 1 of 1
(1,163 Views)
