FPGA compile server question
I want to set up a compile farm system. There will only be one development PC (possibly 1 more later) and one compile worker. The question is, can the compile server (the one that dishes out tasks to the compile worker) be on the same PC used for development, and if so, does this introduce any significant bottleneck compared to using a dedicated machine?
(2,991 Views)
Accepted by topic author ToeCutter
Hi ToeCutter,
The compile server can be on the same PC which is used for development without any issues
Refer to the Getting Started with the FPGA Compile Farm document, available by selecting Start»All Programs»National Instruments»FPGA»Getting Started with the FPGA Compile Farm, for information about setting up and using the FPGA compile farm.
Use "localhost" as compile server hostname for your compilations.
Compile farm server uses the same compilation tools installed (Xilinx) on your PC, but instead of directly getting files from LabVIEW project
it compiles files uploaded by user, hence there is no difference in performance.
I hope it helps!
Kind Regards,
(2,934 Views)
Thanks a lot, Max for the detailed response!
(2,930 Views)
