FPGA compile error when using arrays/clusters
My PCI-7831 board works great until I try to include controls/indicators in my LabVIEW FPGA app. which are either arrays or clusters.  Then the FPGA vi gives me an error "-1" when compiling.   If I change the complex controls back to individual element controls the app. compiles.  What gives?
(2,906 Views)
Garvacious -- Assuming you have given your arrays a size -- there should not be a problem compiling.  If you wish you can post your code and I can take a look at it -- if so, please create the simplest VI possible that reproduces the problem.  Also include all relevant software info and versions you are using.
Doug M
For those unfamiliar with NBC's The Office, my icon is NOT a picture of me 🙂
(2,899 Views)
