FPGA compilation hangs in LV2014SP1
Hello All,
I recently updated to LV2014SP1 from LV2014. Since then, I cannot compile my FPGA VI locally for one project (cRIO9067), which was done in LV2014. Every time I try, the compiler goes into the 'optimizing logic' step. Then, after severyl minutes, vivado.exe drops to using 0% CPU and just sists there indefinitely. After a long time without increasing CPU time for vivado.exe, the compile worker obviously restarts the compilation and the same happens again. Yesterday I let it sit for 4 hours, and when I looked back, vivado.exe had consumed 36 minutes CPU time and was again sitting there with 0% CPU usage.
When using a compile server (still running LV2014), the VI compiles fine from the same project on the same PC! Also, compiling other FPGA VIs for the same and other (cRIO9030) targets works locally.
The identical problem happened on a second PC which was also upgraded to 2014SP1. Even going back to 2014 with the FPGA toolkit and Xilinx 13.04 both did not help - I still cannot compile.
Any ideas or similar problems anyone?
Jörg Heßdörfer
Certified LabVIEW Architect, S.E.A. Datentechnik GmbH
Message 1 of 11
(6,722 Views)
Hey Joergh,
What modules are you using in your project and how are they allocated (FPGA vs Scan Engine)?
We had a recent known car that we just release CompactRIO Module Support 14.6 for but I want to make sure this is the cause first.
Kyle Hartley
Senior Embedded Software Engineer
Message 2 of 11
(6,702 Views)
Hello Kyle,
I'm using 2xNI9264, 2xWireFlow WF3144, and 3xNI9870, in FPGA mode.
    Jörg
Jörg Heßdörfer
Message 3 of 11
(6,696 Views)
Accepted by topic author joergh
Hey Jorg,
Can you download and install CompactRIO Module Support 14.6?
 We released a fix for the 926x modules that were failing compilation with the SP1 compile tools.
Kyle Hartley
Message 4 of 11
(6,684 Views)
Hi again,
yes, I will try it. I will post the results, although it will probably take a couple of days until I get around to it.
    Jörg
Jörg Heßdörfer
Message 5 of 11
(6,670 Views)
Hi again,
I had the chance to test it remotely on my desktop PC, and now it compiled the FPGA code again using the version you recommended.
Thank you,
    Jörg
Jörg Heßdörfer
Message 6 of 11
(6,644 Views)
Hey Jorg,
Glad to hear it worked.
Kyle Hartley
Message 7 of 11
(6,631 Views)
I have the same problem. LabVIEW 2014 SP1 fails to compile for NI 9035 Compact RIO. I installed the Module Suport 14.6 as mentioned in the solution but still have the same problem. The compiler gets stuck at "Optimizing logic" and CPU usage dropes to zero for vivado.exe.
What else can I try? Please help.
Thank you.
Anmol
Message 8 of 11
(6,480 Views)
Do you have the NI RIO 14.5 driver installed?  If not, the 14.6 module won't do anything for you.  NI RIO 14.0 isn't compatible.
Did you update the Vivado compile tools to the 2014 SP1 version or are they still the 2014 tools?
Message 9 of 11
(6,459 Views)
Hello, thanks for the suggestion.
Yes, I had upgraded everything to SP1 first, including the Vivado tools and also RIO to 14.5.
Before I posted my question I had tried a very basic simple VI and it wasn't compiling. It was however not a project I created from scratch. I was working with a project that was created before I upgraded the software and installed cRIO Module Support 14.6. When I created the project from scratch the basic simple VI compiled successfully. I will now try doing that to my main project.
I don't know if that should have anything to do with it but I have some hope.
Message 10 of 11
(6,426 Views)
