FPGA compilation - An error while parsing the document
I'm writing to you as I need help with my FPGA compilation. I try to compile NI 1473R Frame Grabber program but I get an error attached.
I have following products installed:
- NI LabVIEW 2015 FPGA Xilinx Compilation Tools for ISE 14.7
- NI LabVIEW 2015 FPGA Xilinx Compilation Tools for Vivado 2014.4
- NI RIO 15.5
- NI R Series Multifunction RIO 15.5
I have LabVIEW 2015 with FPGA 2015 module, Windows 10 64-bit.
Did anyone encounter problem like this?
Thank you
Message 1 of 8
(5,449 Views)
Do you have enough disk space available?
I ran into some really cryptic fpga error messages due to a disk being full (FPGA module couldn't save and intermediate files).
Message 2 of 8
(5,432 Views)
Yes, I have 273 GB of free space
EDIT: Compilation is successful for other target (sbRIO), so it's rather not problem with disc space
Message 3 of 8
(5,427 Views)
I think you might need the Flex-RIO drivers for that card.
At least according to its datasheet, it requires Flex RIO 13.0 or newer for the card.
Message 4 of 8
(5,422 Views)
I have FlexRIO 15.0 installed (sorry I didn't mention it before).
I have NI-IMAQ 15.0, NI-IMAQ I/O 15.0 and NI-IMAQdx 15.0, too.
Message 5 of 8
(5,381 Views)
Do all VI fail compilation or is it just this VI that you are working with? I would be interested to see if you are able to even compile a blank VI for this target.
Can you also try using the cloud service to compile? I don't think the compile tools are technically supported by W10 so it could be that it isn't throwing an error, just passing back an invalid file.
Message 6 of 8
(5,375 Views)
The empty VI compiles and the VI with one boolean control compiles, too. However, when I place some node on the block diagram (see attachement) the VI does not compile anymore neither for local compilation nor the NI cloud.
Message 7 of 8
(5,360 Views)
I may only add that this happens on two computers.
Message 8 of 8
(5,300 Views)
