FPGA cannot add DRIVVEN module
 Hi, all.
My cRIO is like this.
In project the FPGA can add NI 9411 module, but cannot find the DRIVVEN module. And I've tried to use NI 9751 instead of DRIVVEN in the same slot, FPGA can find NI 9751.Add C module in FPGA.PNG
(4,435 Views)
Should I add some software on MAX?
(4,397 Views)
Maybe at first, you need to connect your cRIO and then try to search your drives.
C.LI
(4,379 Views)
Thanks for your reply!
But, my cRIO is searched, and running well. The problem is my chassis cannot search the DRIVVEN module(All the other module could be searched). DRIVVEN module is used for injection, and its newest production is NI 9751. Before the software in MAX reinstalled , the module can be detected. However, I don't know which software is demanded.
(4,360 Views)
Did you find a solution to this problem? I am facing exactly the same problem with CRIO 9036 and labview 2015
(4,040 Views)
Long after the fact, but someone might still run into this.
The necessary drivers are not installed with the normal CompactRIO drivers but are part of a separate driver that can be installed through VIPM.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OQjSAM
Rolf Kalbermatter  My Blog
(1,037 Views)
