FPGA and VGA
I suppose it is possible to use FPGA to generate VGA signals to control a VGA monitor or projector. Here is a way:
https://decibel.ni.com/content/docs/DOC-6741
But it requires that the target must have a VGA port (for example, Spartan-3E Starter Board).
Here comes my quesiton,
Is it still possible to do so on a borad that does't offer a VGA borad, say myRIO. I've learned that myRIO has reconfigurable IO technologies which we might take advantage of. So how do I implement a VGA drive on myRIO, with labview FPGA? Expecting responses.
myRIO specifications attached.
http://www.ni.com/pdf/manuals/376047a.pdf
Thanks.
(3,739 Views)
Hi
There are a couple of reasons you cannot do VGA output with myRIO
1) VGA requires 3 Analogue Outputs, one for each of Red, Green and Blue.
2) The bandwidth of these signals is too high for myRIO as well. You need 640*480*60Hz samples/s to fulfill a true VGA image. At 345kHz the Analogue output of the myRIO isn't going to cut it.
Sorry
Mike
(3,697 Views)
Well, thank you
(3,685 Views)
So you can't drive a VGA display, but you can use the SPI/I2C/UART communication to display some feedback to the user in the form of a LCD display.  I would link to the demo on Youtube but apparently I'm not allowed to because of a word that is in the link that is not allowed, just search NI myRIO: LCD character display on youtube.
This would allow the myRIO to run headless without needing a PC to talk to.
(3,666 Views)
