FPGA Timing Error
I'm getting this error when I try to compile. Any insights?
Clock Rates: (Requested rates are adjusted for jitter and accuracy)
  Base clock: 40 MHz Onboard Clock
      Requested Rate:      43.230157MHz
      Theoretical Maximum: 46.474880MHz
  Base clock: MiteClk (Used by non-diagram components)
      Requested Rate:      33.037101MHz
      Theoretical Maximum: 66.233938MHz
Timing constraint: TIMEGRP "cRio9205_dio38" OFFSET = IN 16 ns VALID 16 ns BEFORE COMP "dio36" LOW; 1 item analyzed, 1 timing error detected. (0 setup errors, 1 hold error) Minimum allowable offset is 2.536ns.
Hardware: sbrio 9642
Labview 8.6.1
NIRIO: 3.2
Message Edited by InfiniteNothing on 04-19-2010 03:10 PM
CLED (2016)
(4,482 Views)
(4,465 Views)
(4,462 Views)
I tried the solution from the first link though and it didn't seem to work. I wonder why NI doesn't give a bit more information on exactly what that patch fixes.
As for the second link, I'm not using FIFOs or SCTLs at all. I just had an analog input, some math, and an analog output.
I did end up fixing the problem: I moved the analog output to the same node as the analog input using a shift register to carry the data that was destined for the output. I'm not sure why that fixed things and I had that code compiling just fine before some tweaks to the math. I was just hoping to figure out what not to do so I don't hit that problem again. It's frustrating when it takes so long to compile only to throw that error.
CLED (2016)
(4,444 Views)
Glad you fixed it and thanks for sharing the info...:smileyhappy:
(4,429 Views)
