Hi.
I'm using LabVIEW FPGA with a FlexRIO PXIe 7971R and an adapter 5783. My goal is to implement a window to scale my acquired signal before doing a FFT. For my case, something as close as possible to a rectangular window would be perfect (the energy vs time distribution is extremely uneven and i want a good signal-to-noise ratio)
I saw that the Scaled Window Express VI have a implementation option: Show coefficient index terminal
I looked at the LabVIEW help and I did not found what is was.
https://zone.ni.com/reference/en-XX/help/371599P-01/lvfpga/fpga_scaled_window/
My questions are:
What does it do? How does it work?
What is the range of coefficient?
Can i change it to be close to a rectangular window but also to keep the "Apodization" effect at the borders of my signal?
Thank you deeply
