FPGA Sampling problem
hi everybody,
i have a problem with timing on my FPGA,  i would like to acquire a signal at 400khz, and the  analogique/digital converter( NI5731) is working at 40MS/s, so one period of my sinewave should be described by 100 points, but what i see ( picture attached) is that one periode is described  with 23 points. So it seems like the analogic signal  is not sampled at 40MS/s as it should be. Any help ?
Thank you !
Regards
Jean
Message 1 of 12
(5,729 Views)
here are some pictures of my code
Message 2 of 12
(5,683 Views)
Hello jeanT !
You should do like in this example, you have to use a timed loop, with "IO Module Clock 0" on the input clock of this loop.
You can find some basics examples here :
C:\Program Files (x86)\National Instruments\LabVIEW 2013\examples\FlexRIO\IO Modules\NI 573X\
Don't hesitate if you have more questions,
Jérôme Henrion | ONERA - Digital RF Engineer | CLA | CTA
Message 3 of 12
(5,669 Views)
hi jerome !
Tank you very much for this answer i will try to follow the logic of your picture, i don't have the NI 573x example in my computer 😕 could you send it to me please ?
Best regards
jean
Message 4 of 12
(5,662 Views)
for your information, i'm using Labview 2011
Message 5 of 12
(5,655 Views)
Et voilà !! 😉
It should open in LV2011
Message 6 of 12
(5,646 Views)
Thk you very much jerome ! infortunately, the version is still 2013 and labview 2011 can't open it 😞
Message 7 of 12
(5,642 Views)
Yes, unfortunately I can't easily give you those examples beacuse of FPGA toolkit version..
But here you go for FPGA vi
Message 8 of 12
(5,636 Views)
thank you very much ! but i don't have the "data edge trigger.vi" 😕  so i can't run it Smiley Sad
i've got also another question, my aim is to filter the signal that i'm going to acquire, as the butterworth filter is not supoorted into a single timed loop, i got the idea to procede by a FIFO, see attached, but there is a timing problem i presume because the graph don't display the waveforms fluently  😕 it stay freeze.
Thank again !!!!
Message 9 of 12
(5,629 Views)
ok i found the probleme ! no worries 😉 but i still have the problem with the "data edge trigger.vi" Smiley Sad
Message 10 of 12
(5,624 Views)
