FPGA Internal software error
I'm using labview 2009. When I compile the fpga target vi, i got the following message:
" An internal software error has occurred. Please contact National Instruments technical support at ni.com/support with the following information:#,910x,907x,911x,783x;781x,785x;784x,910x,907x,911x,783x;781x,785x;784x,9101;9102;9103;9104,9072;9073;9074;9144;9601;9602;9611;9612;9631;9632;9641;9642,9111;9112;9113;9114;9116;9118,7830;7831;7833;7811;7813,7851;7852;7853;7854;7841;7842,9101;9102;9103;9104,9072;9073;9074;9144;9601;9602;9611;9612;9631;9632;9641;9642,9111;9112;9113;9114;9116;9118,7830;7831;7833;7811;7813,7851;7852;7853;7854;7841;7842,Onboard,Onboard,Onboard,Onboard,Onboard,Derived,Derived,Derived,Derived,Derived#,,,,,,,,,,CONST_TCO_SPI,12.5,13.5,11.25,14.5,12.25,9.25,13.5,7.5,11.25,8.5CONST_TSU_SPI,2,4,3,2,4,4,4,4,4,4CONST_TH_SPI,4,4,4,4,4,4,4,4,4,4CONST_TSU_PLUS_TH_SPI,6,8,7,6,8,8,8,8,8,8#,,,,,,,,,,CONST_TSU_SSMISO,6,6,6,6,6,6,6,6,6,6CONST_TH_SSMISO,4,4,4,4,4,4,4,4,4,4CONST_TSU_PLUS_TH_SSMISO,10,10,10,10,10,10,10,10,10,10#,,,,,,,,,,CONST_9201_TCO_SPI,10,10,10,14.5,12.25,9.25,10,7.5,11.25,8.5
Method Name: <b>Compile For Target</b>"
Does anyone know what caused this problem? Thanks in advance.
(2,640 Views)
Hello Kb1126,
To better be able to answer your question could you please share what RIO device you are working with, the RIO device software and any relevent Xilinix tools versions, as well as the possible version installed on your RT target (assuming you are using a RT controller to interface with your FPGA).
Blayne Kettlewell
(2,623 Views)
