FPGA Improve Code to Fit In Single Cycle Timed Loop
Hello All,
I have the following code below in a single cycle timed loop and I need to get the timing down by about 5 1.2ns. If anyone has suggestions, it would be appreciated.
My inputs are all U16 and can range from 0  to u16 max.
The output determines if the input coordinates x, y are inside the ellipse defined by h, k, a, and b
Edit: the error is by 1.2 ns
(1,765 Views)
(1,742 Views)
