FPGA FlexRIO: Communication error with local compile server
I am trying to compile an FPGA VI for aNI PXIe-7962R with a NI 5751 FlexRIO adapter.
However, when trying to connect to the local compile server, the Compilation Status dialog returns a "Communication Error", finally resulting in the following error message after several communication attempts:
"An error occurred while communicating with the compile server."
The detailed report displayed in the Compilation status dialog is as follows:
The compile server does not have any workers available that can do a Xilinx 11.5 compilation.
* You may not have the correct compilation tools installed.
* The local compile worker may be configured for a different compile server.
* The local compile worker may be in an error state.
Details
Error -123002 occurred at niFpgaCompileFarm_OpenJob.vi
Possible reason(s):
NI-Farm:  No worker has registered the given capability name.
Complete call chain:
     niFpgaCompileWorker_OpenJob.vi
     niFpgaCompile_Worker.vi:1
Start Time: 11:28:01
End Time: 11:28:52
Total Time: 00:00:50
I have the following software installed:
  • Win7 32bit
  • LabVIEW 2010 SP1
  • FPGA 10.0.1
  • NI RIO 3.6 (with FlexRIO 1.6.0 and R series 3.6.0)
  • NI LabVIEW FPGA Xilinx Tools 10.1
What could be a solution to this problem?
(4,394 Views)
The compilation of a FPGA VI for a PXI-7813R card on the same PC works fine.
But here is already the solution to the problem:
http://digital.ni.com/public.nsf/allkb/867A880ADD200C968625777D0060DF31
Hopefully, 10.1 and the 11.5 Xilinx tools can be used in parallel on the same PC, because I still want to use both cards.
(4,391 Views)
Accepted by topic author dlanger
Tested.... Great, the two Xilinx tools (10.1 and 11.5) can be installed and used in parallel.
Furthermore, if only 10.1 is installed locally, an FPGA VI requiring the Xilinx tools 11.5 can also be compiled using the NI compile cloud.
(4,346 Views)
What is the solution.. ? I am having the same problem .. Link not working..
(3,980 Views)
