FPGA Device I/O
How can I get an FPGA I/O Icon on the Function Pallet. I'm using a cRIO.
(4,075 Views)
Hai,
Its easy.
Just check out the attachments.
Navigate to programming>>FPGA then pick the FPGA IO node place it on the block diagram.
or just type "FPGA IO" in search of the functions pallete that will lead directly to the pallete.
With best regards
JK
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(4,072 Views)
