FPGA-CAN data conversion problem
How do I convert 32 bits of data to 16 bits and 16 bits?
Eg:-
My first input is 1000 in i16 format.
My 2nd input is 1000 in i16 format.
When i send this in CAN the the can data received from FPGA is in format of 32 bits.
 i.e the value is coming as 3892570115
How do i convert the above number back to 1000 and 1000??
Input:-
Byte0=1000
Byte 1=1000
Output:-
3892570115
Convert the output(3892570115) back to input as mentioned above.i.e 1000 and 1000
(3,812 Views)
Think in binary:
1000d = 0000 0011 1110 1000 Binary
3892570115 in an unsigned decimal, 32 bit = 1110 1000 0000 0011 1110 1000 0000 0011 binary
So I think the issue is with the endian format of the data, you need to swap the byte order of i16
(3,784 Views)
Accepted by topic author Dhrubajyoti
Here are some simple VI's that I use in my CAN communication.  You can see the conversion from U32 to U8's and vice versa.  The U16's are a step along the way.  One of the VI's shows how to handle negative numbers.  These are all in LabVIEW 9.0.1.
(3,765 Views)
Thankyou so much..
The problem is resolved
(3,749 Views)
