FPGA Analog Output Problem
I wrote code for PXI-7831R(FPGA) Analog Output.
When i excute under Labview environment, this code is no problem.
But, when i make excutable file, FPGA Card don't output minus voltage. (puls voltage is no problem)
What's problem ??
(4,210 Views)
Hi GoodTime,
Can you post your code?
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(4,203 Views)
Thank for your reply, SandmanUK.
i found solution for the problem last night.
i connected numerical result (double type) directly to FPGA Analog Output.
So, i inserted  numeric conversion (To word integer), then the problem disappear.
i think  auto type-conversion-mechanism of LV have internal Bug.
--- between "LV Environment" and  "Start Up Excutable"
(4,196 Views)
I see. I don't think that the FPGA supports double types.
(4,190 Views)
