FP Read (Float Array -IO).vi request
Whenever I use the FieldPoint palette item under Input or Output I get a message asking for FP Read (Float Array -IO).vi and then FP Write (Float Array -IO).vi This vi is not present anywhere on my harddrive and a search of this website came up with nothing. The Fieldpoint palette item does not work properly when I choose Cancel - the input or output value becomes an integer (I think) that does not actually read or write data. What is this error, and how do I fix it?
Message 1 of 8
(4,473 Views)
The VIs that are missing should be in the ...LabVIEW\vi.lib\FieldPoint\Polymorphic Read.llb and ...LabVIEW\vi.lib\FieldPoint\Polymorphic Write.llb files. If you are missing them, it is likely that your installation has become corrupted. You can copy the above files from a different computer or re-install the NI-FieldPoint driver.
Aaron
LabVIEW Champion, CLA, CPI
Message 2 of 8
(4,470 Views)
Wrong filename - I get a message asking for FP Read (Float Array -IO).vi The files present in the files you named are the same but without the -IO part. I've looked this up on another computer that doesn't get the error message and the files are the same.
What gives with the -IO?
Message 3 of 8
(4,470 Views)
The easiest way for you to resolve this issue will be to reinstall your FieldPoint driver. This will repopulate these VIs and resolve the problem.
Bill B
Message 4 of 8
(4,470 Views)
Getting the exact same problem myself.  Only installed it on this PC 2 days ago though.  I'll try the reinstalling bit and see how it goes.
Message 5 of 8
(4,365 Views)
Still getting no joy from that.  Smiley Sad
Message 6 of 8
(4,358 Views)
Morning all!    Any ideas on this matter over the weekend?  I'm stumped myself.
Message 7 of 8
(4,344 Views)
I'm curious if you ever figured it out, I'm having the same problem. uninstalling and reinstalling the fp 4.1 does nothing at all. Jim
Message 8 of 8
(4,303 Views)
