FP-PWM-520 8-Channel, 5 or 24 V PWM generator can support LABVIEW?
Hi everybody,
FP-pwm-520   8-channel , 5 or 24 volts PWM generator can support LABVEW ?
It is programmable but iam not understud how we can connect the Instrument to computer i.e. which hardware link it can support..( like GPIB, USB or PCI).
And suggest me to application software which is compatible to this Instrument.
Thanq,
Mahesh.
(2,623 Views)
Hello Mahesh,
The FP-PWM-520 is an I/O module and cannot directly communicate with the PC.  You will need a FP Controller (such as the FP-1000, FP-1600, or FP-20xx) in order to establish communication between your I/O modules and the comptuer.  Do you have one of these controllers?  The FP-1000 uses a serial interface to communicate with the computer and the FP-1600/FP-20xx uses a TCP/IP interface.
In terms of the application software, LabVIEW should work great with your Fieldpoint application!
Eric
DE For Life!
(2,616 Views)
