FIR FILTER CONTROL
Hello
I am new to LabVIEW and have problem with FIR fillter control.
I have usual FIR filter which has Lower cut off frequency control. But
it does not have taps control. Is it possible to make taps control to it or to select other block with same properties as this FILTER block?
Thank you for your answers.
(2,453 Views)
Hi DODI,
I think your question was answered in this topic:
http://forums.ni.com/t5/LabVIEW/FITTING-IN-XY-GRAPH/m-p/1619242
If you need more help, please write the details here and I'll try to find a solution for you!
Virdzs
(2,413 Views)
