FIFO DMA
Hello/Bonjour
I try to pass some data trought DMA FIFO but I have a problem of synchronisation.
I hope to read on rt 0 as 1 data, 1 as 2nd etc..
Any idea?
J'essai de paser des données (0,1,2,3..6,7) depuis un FPGA vers un RT mais je n'arrive pas à lire les données dans un orde fixe genre, le 0 en 1er puis le 1 etc..
Une idée de ce qui cloche dans mon code?
BR/Merci
(4,812 Views)
Any Idea about what?
It looks like you have FPGA code writing to the FIFO, and PC code to read from the FIFO.
What is your question?
(4,807 Views)
The question as far I understand is that the numbers 0,1,2 and 3 are missing.
I would suggest you to log the data and check, I believe you are getting all the data but the indicator shows the data after 5718 iteration. Also instead of writing only 8 data write 100 data (iteration value in the FPGA) so that atleast you don't have any confusion seeing in the indicator.
(4,789 Views)
OK.. if you look data of front panel of RT vi,
you can see Data[0]=4 Data[1]=5 etc..
So i would like to have Data[0]=0 and Data[1]=1 and Data[8]=0 etc
did you need more precision ?
(4,786 Views)
Can you do what I have suggested and show the result?
(4,779 Views)
Accepted by topic author AFLAMENT
Found!
I read 100 element and write 8 by 8 element, 100 is not a multiple of 8.
read 80 element work
(4,768 Views)
P@anand hit the problem on the head.
You are sending batches of 8 elements at a time.  You are reading 100 elements at a time.  100 is not divisible by 8.  So in one iteration, the first 4 elements of the hundred grabbed will be 0, 1, 2, 3.  The next iteration, it will start 4, 5, 6, 7.  100 elements will only give you 12.5 batches of 8 elements per iteration.
Try making your number of elements to read a value divisible by 8.
(4,757 Views)
