FGV timer usage
Thanks..
the while loop for a state machine will work, right?? I do not need to add another loop, right?
also where should I put the reset FGV? outside the state machine? or the previous case within the same state machine?
Message 11 of 14
(1,488 Views)
You do it in your state machine wherever you need the timer to be reset.
Message 12 of 14
(1,485 Views)
Thanks but if you put the "read time" in the same case where you "reset" the timer, the "read time" FGV does not respond..
Message 13 of 14
(1,482 Views)
Right. You want to reset once and then continually read. fF you reset every time you read, you will always be measuring (TimeNow-TimeNow) as your elapsed time (=0).
Message 14 of 14
(1,473 Views)
