FFT the signal which read from analog pin through Arduino
I installed LINX but I did not see the Continuous_Sampling function (only Analog_Read function). I need to set up some parameters like acquisition time and samples to read (similar to LIFA).
If I use the analog read function (1 Chan), the voltage output can't connect to waveform. what am I missing?
Message 31 of 36
(2,430 Views)
Hi Lucbk,
Your topic I have very interesting, so I now same problem with you. I wanna read analog signal through Arduino then process out to spectrum chart by Labview. Now I using Labview 2014 with LINX. I now waiting someone help to this Topic. Please, please help us.
Message 32 of 36
(2,041 Views)
Hi there, you can send message to me. I will try to share if I know
Message 33 of 36
(2,022 Views)
Dear Lucbk,
Thank you for your kind. I have to read analog signal from gyro sensor MMA7361 with Arduino Auno, aimed for measure the RPM of turbo charger. So I have attach picture of my vi it can see only analog read  without freq wave form. Could you advise please?
Thank you in advance,
Jakkrich S.
Message 34 of 36
(2,010 Views)
Hi jakkrichs
My understanding, you can not analyze the spectrum with "Analog Read 1 Chan" Output. Try to build it into an array or use Spectrum analysis tools in "Point by Point" if you want (Signal processing => Point by Point => FFT,...)
You should test with Signal generator first, (for example, generate a sine wave 1V 50Hz then connecting to Arduino pin to read analog and see its spectrum)
Message 35 of 36
(2,004 Views)
what FFT VI you use?
Message 36 of 36
(1,685 Views)
