FFT question
Dear,
I have never used FFT function to identify some frequency of the data.
The attached data should be shown in 1 Hz or 0.5 Hz. (not identified easily after transforming in my eyes.)
If you open my vi, you can find the original data and transformed result.
Would you please check my simple code? Am I right?
*) I got to know there are so many FFT functions in example code and I found only one vi can be applied to my code.
What's the difference among them?
(2,680 Views)
Labmaster-
My suggestion would be to use the FFT Spectrum (Mag and Phase) VI to find a simple FFT. It takes a waveform as an input and returns a magnitude and phase waveform. Here's  a different rendition of your code using the same min/max filter you had in place.
Xaq
(2,639 Views)
Dear,
Thank you for the reply.
I have already used the function, but as you can see, there is no different thing when I used my function.
Thank you.
Lee
(2,612 Views)
