FFT plot of sampled data
I already have sampled data of a input signal in time domain. the signals are sampled via ADC and stored in excel file(around 16K samples). I need to feed it to FFT VI to obtain the FFT plot. I tried multiple FFT VIs but no one accept samples data directly which is stored in 1D array. Any ideas? Thanks.
(12,628 Views)
Signal Processing >> Transforms >>  FFT
That takes data stored in a 1-D array.
(12,621 Views)
Hi , The FFT.vi was my first line of defence. The plot I'm getting after converting ignoring the imaginary part and just taking the real part doesn't seem to give correct amplitude.
I also need to use window (Hanning) but if I try inserting window then it give some wrong data.
Attached is my VI. If that helps.
(12,618 Views)
Accepted by topic author ABM26
Hi ABM26,
Your input signal seems like a pure sine wave.  And you perform the FFT and get the amplitude.  So you get two peaks in the result.  I think this is reasonable result.   Why do you think the FFT result is wrong?
And I notice waht you want to compute is power spectrum.  You can use Signal Processing >> Spectral Analysis >> Power Spectrum.vi directly.
(12,607 Views)
In the link below I have posted a FFT example. It is quite old made in Labview 6I but it does all you need. Please take a look at it.
http://forums.ni.com/ni/board/message?board.id=170&thread.id=163587&view=by_date_ascending&page=2
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(12,604 Views)
