FFT on DAQ
I   want to apply FFt on my data that iam acquirng from NI card.I am measuring Pressure and flow rate . i want to apply FFT on these data. i want to  know which  is more suitable way of doing this
1. should i save the data in array and then  pass this array to power spectrum VI of FFt
2. or should i directly connected my incoming signal to input of the Power spectrum VI. I am acquirng data at a rate of 1000 Hz  but during FFT number of samples are also important i want to know if i directly connect the incoming signal than how could i determine what are my number of sample of incoming data.
(2,898 Views)
Hey Dost,
You've probably seen the answer I posted on your thread
But in case you haven't, I thought i would let you know.
Hope the information helps,
Peter H
Applications Engineer.
NIUK.
(2,891 Views)
