FFT(mag phase) and sample count
I am using the FFT(mag and Phase) VI in version 6.1.  When the sample count sent to the fft vi is increased the magnitudes decrease.  What is causing this?  Does the VI divide by the sample count?
In advance, thank you!
(3,107 Views)
The resolution of FFT depends on the sampling rate as well as the number of samples used to compute FFT (Fs/N). When you reduce the number of samples, the resolution of FFT comes down. This means that the peak that you detected prevously might have gone undetected.
Kallis
BR
(3,102 Views)
Yes,  I have kept the sampling frequency the same and the amplitude of the noise has increased by ~ 5x.  So, if there are noise spikes at a low sample count they will not be "averaged out" by the fft?
(3,092 Views)
What do you mean by 'amplitude of noise'? Can you post an image of the two cases that you are referring to. Did you enable averaging in the FFT vi?
BR
(3,074 Views)
