FFT algorithm routines in Labview
Real FFT.vi uses the fast radix-2 FFT routines or a mixed radix cooley-tukey algorithm in Labview.
Do these kinds of routines have the 2N-point real FFT method?
2N-point real FFT method is to utilize the single complex FFT by processing  two seperated N points (even index data- real N-points input, odd index data-imaginary N-points input in single complex FFT routine)
And what are differences between radix-2 FFT and fast radix-2 FFT routines?
And  what are differences between cooley-tukey algorithm and mixed radix cooley-tukey algorithm ?
(3,172 Views)
If I understand you right, you could just typecast your interlaced array into a complex array of half the lenght before feeding it to the complex FFT.
Can you explain your concerns about the algorithms. Maybe wikipedia will help?
(3,162 Views)
