FFT Spectrum from 2D array
Your data has a gigantic DC offset, meaning that most of the result will be at zero frequency. Set the y-axis of your graph from 0..0.1 and you'll see the other frequencies. Alternatively, you could set the mapping of your Y axis to logarithmic.
Your data also seems to be in segments different offsets and contains some random spikes. Maybe you should analyze it in segments. Also, your data variation is relatively small compared to the digital resolution, meaning the data is quantized to relatively few levels.
Maybe you could record the data with the offset removed and with more gain, appropriate to the data range.
What does the data represent and what are you trying to get out of it. Just blindly throwing an FFT at something does not magically solve things. What's the reason for the transform?
Message 21 of 23
(725 Views)
Thanks very much for your help..
So, my block diagram is no problem, and the problem is the data, right? Okay..
Actually, i want to compare my fft result from  Senscope ( software from the sensor vendor ) with labview.  The data come from vibration sensor. I get those data by shaking the sensor ( ???) .  Maybe you have the similar data , so i could try on my own?
NB: Hello everyone, i need real sensor data in excel format . If anyone has, please share to me... Smiley Wink
Message 22 of 23
(711 Views)
i try with another data, and success !!! Smiley LOL
Thankyou
Message 23 of 23
(701 Views)
