FFT 2D ?!
Anybody knows where i can find a labview vi that performe a 2D FFT?
Thank you
Olivier
Dr. Olivier Albert / aolivier@eecs.umich.edu
Center for Ultrafast Optical Science, University of Michigan, USA
tel: (734)936-4806 fax: (734)763-4876
(7,111 Views)
Olivier Albert wrote in message ...
I seem to remember that one of the examples in the LV 5.0.1 Distribution as
some 2D FFT capability - I can't remember the vi name though.
However if you are stuck a simple implementation of 2D FFT is
1) Wire your 2D data set into an indexing for loop
2) Within the loop FFT the 1D data arrays
3) Upon finishing the loop you now have data which is
in the Fourier domain along rows but in the temporal/
spatial domain along cols.
4) Use the transpose 2D array function to swap rows and cols
5) repeat steps 1 and 2
6) Remeber to use the transpose 2D array function to swap rows
and cols back again.
NB this routine will ret
urn the data in a quadrant shuffled format
(i.e. with the +/- Nyquist/2 values in the centre of the array)
For further info on the FFT (including 2D - FFT and quadrant
arrangement) try having a look at
"The Fast Fourier Transform and its Applications" by
E. Oran Brigham Publ: Prentice Hall
Regards
Andrew
(7,111 Views)
