取消
显示结果
搜索替代
您的意思是:
F->T rising edge detection
已解决!
转到解答
I'm trying to figure out any way or somethink, which detects the rising edge and the output value will be true (when the state changes from 0 to 1).
So if the input is 0, output is false. When imput is 1, output is false. Just that moment between 0 and 1 should be True at output.
Do you have any advices plese? 🙂
thanks, pelda
0 项奖励
1 条消息(共 4 条)
9,824 次查看
A shift register and the Implies function.
Lynn
0 项奖励
2 条消息(共 4 条)
9,823 次查看
解答
已被主题作者 peldao 接受
Feedback node and greater than function.
Or boolean Crossing Pt by Pt.
3 条消息(共 4 条)
9,807 次查看
Thank you very much.
0 项奖励
4 条消息(共 4 条)
9,739 次查看
