Extremely Precise Timing
I want to create a while loop that iterates EXACTLY every 1ms. Any ideas?
(4,713 Views)
Use LabVIEW real time, or even LabVIEW on an FPGA which can run loops at 40MHz.
You can use a timed loop in Windows but that timing cannot be used reliably because Windows is not deterministic.
(4,712 Views)
What do you want to do at exactly 1ms? There may be a workaround without RT.
PaulG.
Retired
(4,684 Views)
I want to count pulses for 1ms, then reset the counter and then count again pulses for 1ms etc.
(4,644 Views)
I take it this is in relation to the other thread you started for which you haven't received an answer?
(4,641 Views)
Hi Evangelos,
why do you want to reset the counter? Using a shift register and taking differences (by subtraction) is much more easier...
Also:
- Using your USB6009 on plain Windows isn't the right environment for "extremely precise" timing (as said before).
(4,626 Views)
Here's a community example that shows how to do this using hardware timing: Use Counter to Create a Clock for a Buffered Edge Counting Task
However, it won't work with a USB-6009 because it requires a device that supports multiple counters and buffered edge counting (e.g. TIO, X Series, cDAQ, M Series).
Brad
Brad Keryan
NI R&D
(4,602 Views)
