Extract numbers from string output
Hi
I would like to know what is the most efficient way (in terms of execution speed) to extract the red highlighted numeric values from this string output:
1536x1103 0.83X 32-bit RGB image 85,85,85 (748,668)->(844,859) [213.77,296.68°].
I have attached a sample vi. Is this an efficient way to code it (in terms of execution speed)?
- Sable
(3,283 Views)
Hi
- Sable
(3,287 Views)
I think the Search/Split String is supposed to be a little more efficient than Match Pattern as it uses a much simpler search algorithm (byte search instead of regular expression).  Otherwise, you have exactly what I would do.
(3,271 Views)
Accepted by topic author Sable
You only actually need one space in your format string.  This will detect 0 or more white spaces (spaces, tab, linefeed or form feed).
aputman
(3,237 Views)
